| | | Forums66 Topics128,290 Posts1,058,554 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Have just finished wiring my 53 3100. Would like to know if anybody has found an Amber 6 Volt Park Light & Turn Signal Bulbs? The wiring harness came with the double contact sockets already attached. Just had to drill out the hole in the back of the park light, to 3/4 of an inch. Don't want to put Amber lenses on them. I like the stock look. Any advice or guidance would be greatly appreciated.
Thanks, Rugo
Steve Rugg 53 3100
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Is it a BA15 base? Are the pins offset or straight across? If you know the number of the bulb you can google it. The 1154A might be what you're looking for.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You should look to vintage VW suppliers. VW changed from 6 to 12 in about 1966 and these bulbs were common to Karman Ghia models. Here are some from eBay you can look at: Search for item# 321524599103 $3 each limited supply.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Should be able to google obsolete bulb numbers. Just look for 6V or 12V and you should be good to go. Jeffrey | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Thank you guys for your guidance. Tiny, I took a look at the inventory in the website that you attached. I have just emailed the fellow about some products. Brad, good idea with the VW angle. I will widen my search, to include VW 6 volt bulbs. Tim, I like the idea of the LED, for the brightness and the lack of voltage it needs. Just not sure I want all those little lights shining through my clear lense. Trying to stay a bit more period correct. Though, I have not ruled them out. I really appreciate your help guys. If anybody else has any other suggestions, please let me know.
Thanks, Rugo
Steve Rugg 53 3100
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | In the event that anybody else is looking for bulbs for your 6 volt systems, the link that Tiny attached to post was very helpful. Some of the bulbs were available at NAPA, or other parts store. The Amber Park Light/ Turn Signal, wasn't available in the 6 volt version. But the 1154A, was available and at a fair price. Here is the link again. http://www.taillightking.com/light_bulbs.htm I have some on their way now. Thanks to everybody that gave advice and direction. Rugo
Steve Rugg 53 3100
