1 members (MickeyP), 110 guests, and 3 robots.
Topics128,193
Posts1,057,253
Members48,466
Hey guys, Well its not a stovebolt but I knew your expertise would help me out. I just purchased a '59 Rambler American. This car has been in a garage for 10+ years without starting it or anything. Flathead 6, 3 spd. Where do I begin in the process of just getting it to run. WD40 in the cylinders to make sure its free? I'm listening...........
Later,Bill
Here are two recent threads on the subject.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=006601#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=007104
Fred
52 3600
69 C-10
Novatatto send me an email and I will send you the name and number of a local guy that runs a nash club.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
WD-40 might not be the best choice as a free-up oil. I'm partial to Kroil, made here in Nashville, (www.kanolabs.com), but Liquid Wrench or PB blaster will do more to free up stuck rings, etc, than WD-40. Check out the ignition system, points, plugs, etc. If there's any stale gas in the tank, ditch it, and refill with fresh stuff. Cooling system, drain and refill with 50/50 antifreeze and water. Inspect the radiator for corrosion after it's drained, repair if necessary. Inspect and/or replace radiator hoses, fan belts, etc. Install a hot battery, clean or replace cables. Once it's running, do a thorough check of the brakes before hitting the road. Brakes are usually the first thing to go in long-term storage, even befor engine problems happen.
BTW, I've got a 1960 Rambler American 2-door wagon that's been parked since 1984, waiting on shop space for a restoration.
Hey gang the Rambler is home. Go here to see the pics. http://community.webshots.com/user/novatattoo
Later,Bill
NICE! cool
You have too many oil cans, BTW! wink
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
