4 members (Otto Skorzeny, Johnny Rib, dwreills, 1 invisible), 95 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#1199659 01/14/2017 3:17 PM
Will the distribor and fuel pump from a 235 engine fit on a 256 engine. Tks. Mike
Mike,
1940-1941 256 ci GMC engine?
I do not know about distributor compatibility, but it looks like the 256 was similar to the 270. Maybe someone knows about the 270 distributor compatibility with 216/235?
Its a beast I mean orphan all to its own.
Search WW2 military resto sites. It was only used in military applications for a very short time.
No joy for cross motor parts swapping to a 248/270/302
Give me ambiguity
or give me something else
It's a 270 bore with a 248 crankshaft. He's using 270 rings, and all the bearings are the same as the other GMC inline engines. He's concerned with whether a cast iron or a steel gear will be required, assuming the 235 distributor has the right dimensions to plug into the GMC block. I think (not sure) a 235 fuel pump should bolt on and work OK, but that's easy to figure out.
