7 members (48jim1ton, 2-Ton, JW51, Jman, 32Fordpuchoptop, Jay R, Peggy M),
92
Mod | | | Forums66 Topics128,042 Posts1,055,601 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | Will the distribor and fuel pump from a 235 engine fit on a 256 engine. Tks. Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike,
1940-1941 256 ci GMC engine?
I do not know about distributor compatibility, but it looks like the 256 was similar to the 270. Maybe someone knows about the 270 distributor compatibility with 216/235? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Its a beast I mean orphan all to its own. Search WW2 military resto sites. It was only used in military applications for a very short time. No joy for cross motor parts swapping to a 248/270/302
| | | | | Joined: Feb 2004 Posts: 29,761 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,761 | It's a 270 bore with a 248 crankshaft. He's using 270 rings, and all the bearings are the same as the other GMC inline engines. He's concerned with whether a cast iron or a steel gear will be required, assuming the 235 distributor has the right dimensions to plug into the GMC block. I think (not sure) a 235 fuel pump should bolt on and work OK, but that's easy to figure out. Jerry
