| | | Forums66 Topics128,196 Posts1,057,390 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 19 New Guy | | New Guy Joined: Nov 2005 Posts: 19 | I'm still trying to figure out if the bed on my 5? is actualy from a 54. After looking at some pictures of my bed side's and pictures of other "Known" 54's there is some difference's . The flat top on mine does not end in a roll . It is squared off. This make's me think that the side piece's are hand made by the previous owner. I'm trying to determine if the bed is a hand made 53(using the 53 height specs) made with a a flat top . Or if it is a true 54 using the 54 height specs.
Can someone measure the top of the bedside to the bottom (bed floor) by measureing on the inside of the bed. I need both a 53 and a 54 measuement.
I will try to figure out how to post a picture so you folks can see what I'm talking about.
Thanks Rick | | | | | Joined: Nov 2005 Posts: 19 New Guy | | New Guy Joined: Nov 2005 Posts: 19 | Well It looks like I can't attach a piture of my truck. If your interested in helping me figure this out. I can email you pictures of the bed sides.
Thanks again Rick | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Rick, I do not have measurements but here are some pictures. Tim | | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | Rick,
I do have both beds, a 53 and a 54. They look just like the pictures Tim sent with the rolled top. Measuring vertical inside the bed from the angle on the bed floor to the bend in the top of the bed, the 53 is 14" and then angles up, the 54 is 17 1/2 and then angles 90 degrees.
Ron
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
| | | | | Joined: Nov 2005 Posts: 19 New Guy | | New Guy Joined: Nov 2005 Posts: 19 | That should be what I'm looking for. I will measure mine tonight and see what I have.
Thanks for the help
Rick | | |
