1 members (1 invisible),
100
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Am attempting to repaint the interior cab and I got about 4 spots where it is orange peeling. sand them down and reshoot with enamel, they comee right back. most of the job looks good, just those 4 spots. answers? | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Sounds like a reaction between the primer and the paint.Try cleaning the area really good and put a light coat of primer over it ,sand it,clean it again and repaint.It also could be a fisheye problem where there is oil or some other problem. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Gazim, I don't mean to be a wiseguy, but are you sure it's orange peel, or is the paint wrinkling up on these spots when you spray them. There is a difference. Orange peel is just a surface imperfection and can be taken care of by color sanding and buffing. It almost sounds like what you have is a "wrinkling" effect where a contaminant on the metal such as oil or grease is not allowing the paint to adhere to the metal or the primer. Even an oily finger print is enough to make this happen. If this is the case, the only way to cure it is to remove the contaminant by re-preping the area. Sand, clean with a good wax and grease remover, re-prime, then re-paint. Good luck.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | orange peel fingerprints If these areas have been filled it could be shrinkage Or possibly wrinkling Hope this helps.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Guess I didn't know what I was talking about. It is wrinkling. happens within 3 min. of spraying it. I bet it was waxed at some time and I didn't remove it properly. thanks guys. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Please let us know what you do, and how it turns out. It's nice to have a follow-up on this stuff so everybody knows if the advice given works or not.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Will do, I sanded it down and repainted it to limited sucess. Got rid of about 75%. Will try cleaning it with solvent next and advize thanks dad & pakrat. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Try TSP (trisodium phosphate)after you clean it. This is a good degreaser, water soluable and easy to find. | | | | | Joined: Mar 2006 Posts: 9 New Guy | | New Guy Joined: Mar 2006 Posts: 9 | One point worth mentioning here is the type of towel/rag you use to clean or scrub with. Old shop rags may look clean but they can hold grease and oil for a good while. The shop I work for uses several products to combat fisheyes and wrinkling. We wipe down the work area with a product from Dupont (3900) on a clean heavy paper shop cloth, then we spray an aerosol windshield cleaner and scuff the area with a gray (1200 equivalent) scotchbrite pad for adhesion.
Need more space for VEHICLES in the list area! Maybe I just need to thin the herd...
