7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible), 41 guests, and 1 robot.
Topics128,091
Posts1,056,034
Members48,433
#119891 03/16/2006 5:08 AM
Junior Member
Junior Member
How do you remove door glass? I have a '48, with one piece windows. I have removed the screws that attach the glass to the regulator, and I have also removed the inside frame. The glass is loose, I just can't seem to get it out of the opening. There is a ribbed channel that is in there also. Does it come out? Also, what parts do I need to get to re-build the doors? Scrapers, windlace?
Mark
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
#119892 03/16/2006 5:16 AM
Hey Mag, Welcome. Once you have the 4 screws out that hold the window to the regulator, and the inner window frame off, roll down the regulator, tip the front of the window down into the door until you've rotated it a 1/4 turn. Now the top of the window should be facing the front of the door. From here you should be able to tip the window toward you as you lift it out of the door. You do not need to remove the glass run channel to remove the window.
Keith
If it were easy they'd have grade schoolers doing it!
