0 members (),
50
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I have been using an old seat cushion out of an old tent trailer to lay on while I'm under my truck. It had great foam, perfect size 2x4', had nice dark brown tough fabric to camouflage the grime. Well, needless to say after a couple years of work, welding and naps she was in very rough condition. A couple times I caught it on fire 😳.
Not anymore! I was given a large roll of excess fire blanket material from my brother and proceeded to rewrap my old cushion. It is so awesome to nap...I mean work comfortably under the old 1 ton again. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Very important, and often forgotten requirement of a creeper is quality napping. I recently picked up one from Northern that had an adjustable headrest so you do not have to hold your head up. Bolter meditation indeed.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Apr 2018 Posts: 6 New Guy | | New Guy Joined: Apr 2018 Posts: 6 | I know this is an old post now but I will share this anyway. hopefully someone may benefit from it. I keep a little childs "prescool" nap pad that folds up under my truck seat so if i nto crawl under the truck for any reason its as comfortable as a creeper. its a smooth vinal with a foam core inside. if it gets dirty just wipes off. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think they are called "kinder mat"? | | |
