9 members (Gdads51, Shaffer's1950, 78buckshot, Phak1, Leo, dt235sd, Jon G, mick53, 4tttt8),
87
Mod | | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 14 New Guy | | New Guy Joined: Dec 2012 Posts: 14 | Hey guys, been a while. Finishing a truck interior and found that I don't have the trim for the center where the headliner panels meet. bought one from someone else but looks to be for a 40's truck with a higher top. I may can alter this one to work but rather install the correct trim. My time is running out fast, this was the last stuff I had to do and now I'm stuck and my buddy returns from deployment in one week, Anybody got one or want to trade. Bob needs help. | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | I do (have one) from my 51. I heavily insulated the cab including the top and went with a one piece abs plastic headliner. That said, I've made it a point to keep all the original pieces and am not currently ready to part with anything. My suggestion is give these folks a call, RPM Motorsports. They part out a lot of AD trucks. , you'll find them here. http://stores.ebay.com/RPM-Motorsports-I...d=p4634.c0.m322No affiliation and never bought from them, I just always check their site when I need something. Good Luck, Ron
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | First you list 47-50 as your span of years and there are some real differences here. 1947 and 1948 (some early 49's) use a screw on center bow, this bow attaches to another spot welded inside the cab. https://www.flickr.com/photos/advance-design_parts_co/18770380205/in/album-72157631867396207/The later bow shaped like an "S" floats and the cardboard essentially holds it in place. If you do not have the early style as shown you need the "S." The early also uses a different cardboard set that is cut/notched for the screw-in bow. | | |
