0 members (),
94
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | will a 235 intake exhaust manifold fit on a 216 engine? | | | | | Joined: Feb 2004 Posts: 29,832 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,832 | You'll need a set of special stepped-down intake alignment rings to be sure the smaller-diameter 216 intake passages center in the 235 manifold ports. A 216 carburetor will not bolt onto a 235 manifold, and the 235 carb will run lean on a 216. Jerry
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | It depends on the year. My '46 235 had the same manifolds as a 216, the '53 235 I replaced it with has different manifolds. | | |
