Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Phak1, ShopRag, RLB, cmayna, Dakota Bob), 129 guests, and 2 robots.
Topics128,282
Posts1,058,492
Members48,490
#1198352 01/05/2017 4:55 AM
will a 235 intake exhaust manifold fit on a 216 engine?
You'll need a set of special stepped-down intake alignment rings to be sure the smaller-diameter 216 intake passages center in the 235 manifold ports. A 216 carburetor will not bolt onto a 235 manifold, and the 235 carb will run lean on a 216.
It depends on the year. My '46 235 had the same manifolds as a 216, the '53 235 I replaced it with has different manifolds.
