| | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Hey guys. From what I can tell, the sheet metal on the cabs of the 47 trucks are all the same right? I have a Loadmaster 2 Ton. Is that the same hood they used on a 1/2 ton truck? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | late 47, looks same as 48-53.
Cabs are the same from 1/2 ton up for all Chevy and same up to a GMC 400 series (600 series same/similar?). Excluding COE's. Hoods, fenders and the rest of the front clip is same for 1/2 through 1 ton, then 1.5 and 2 ton Chevy (and GMC) are different, then 400 series GMC is bigger yet. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | Hoods, fenders and the rest of the front clip is same for 1/2 through 1 ton, then 1.5 and 2 ton Chevy (and GMC) are different, then 400 series GMC is bigger yet. I never wanted to believe this for the longest time, but I recently had an opportunity to put a tape measure on a 1/2 ton 47-54 truck hood and compare it to the hood on my '50 4100 - it was about 1 7/8" shorter depending on how you measured it. I swear you could put those two hoods on the ground 50' apart and you'd lose your [censored] on a bet they were identical. lol Edit: The grilles on the 1.5 ton and larger 47-54 trucks are also different - albeit seemingly identical in appearance, the big trucks' grilles are taller.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 1 1/2 ton and larger hoods are shaped different at the lower back edge. | | |
