1 members (Samantha), 45 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#1198205 01/04/2017 2:37 PM
Hey guys. From what I can tell, the sheet metal on the cabs of the 47 trucks are all the same right? I have a Loadmaster 2 Ton. Is that the same hood they used on a 1/2 ton truck?
ljblue #1198207 01/04/2017 2:56 PM
late 47, looks same as 48-53.
Cabs are the same from 1/2 ton up for all Chevy and same up to a GMC 400 series (600 series same/similar?). Excluding COE's.
Hoods, fenders and the rest of the front clip is same for 1/2 through 1 ton, then 1.5 and 2 ton Chevy (and GMC) are different, then 400 series GMC is bigger yet.
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #1198240 01/04/2017 5:55 PM
I never wanted to believe this for the longest time, but I recently had an opportunity to put a tape measure on a 1/2 ton 47-54 truck hood and compare it to the hood on my '50 4100 - it was about 1 7/8" shorter depending on how you measured it. I swear you could put those two hoods on the ground 50' apart and you'd lose your [censored] on a bet they were identical. lol
Edit: The grilles on the 1.5 ton and larger 47-54 trucks are also different - albeit seemingly identical in appearance, the big trucks' grilles are taller.
1950 4100 - unrestored and driven weekly for almost no reason at all.
ljblue #1198454 01/06/2017 12:08 AM
1 1/2 ton and larger hoods are shaped different at the lower back edge.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
