| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 10 New Guy | | New Guy Joined: Oct 2005 Posts: 10 | I'm thinking of getting a spray in bed liner. I have a Rhino liner in one of my trucks but I was wondering if there is a better product out there? Some people say Line-X is better but I have heard it does not keep it's color well and turns chalky. Any comments?
bw
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Perfectly happy with my Line-X lining. I think it will all fade over time but have not seen any chalky linings. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Linex is far superior to the rhino lining.You can have paint added into the mix, it cost about $200.00 more to do so.The linex will not peel like rhino, it is a urethane based coating(3/16 thick). I know it takes a special spray gun that has a heating element in the hose,it is applied around 375 degrees.I was very impressed about the whole process,it was cool. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | Has anyone used either of these for the underside of your rear fenders or your stepsides. I have a 50' and was thinking of doing it. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I spoke to a fellow that has a Line-X franchise in Lawrence about shooting the inside of my '66 K10. I have the cab striped to repair the kicks, inner rockers and floor pans. I want to shoot it from the top of the firewall under the dash, down the kick panels, the floor pan and up the back of the cab to the bump-out right below the window. I am also going to shoot the flat surface of the rocker panels at the door sill, due to the wear and abuse from getting in and out of the truck.
The Line-X will provide rust protection, vapor barrier, sound deadening and a slight amount of insulation value, not to mention it will look cool up under the dash instead of the black cardboard fire wall cover and behind the fuel tank instead of unpainted interior. What do you think. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have the running boards and the inside of the tunnel box(big tool box)of my '53 wrecker done with the spray liner kit that Eastwood sells.It has held up well(8 years so far).I also have my Toyota pick up bed done with Rhino.Metal prep is the key to success! ** 4-5-6 Chevy Trucks,I checked out that Red 65 wrecker.What a sharp truck!!Give us the specs on that beast especially the front winch.Is it a Garwood ex-military?
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I used the stuff they sell at walmart it has held up really well. I would be concerned about the weight that would be added if it was linex'd. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | We painted the interior under the dash, under the bench seat and behind the seat with the stuff from Eastwood. Then it was painted over with the interior color. http://community.webshots.com/photo/483681592/2962068700080243953BtFQCm It seems to make the metal thicker and might cut down on road noise and heat (once we get it back on the road). I like it and it seems that nobody will see it once all the parts covering it are installed. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Tony,I think you will be very pleased with linex,it's indistructable.I think you will not hear any road noise with the windows up.I would'nt cover any nuts and bolts with it,you'll never get the loose in the future. 3m makes a rubberized coating called body shutz. I used it in my 1951 chevy truck.It's black,but i painted mine my body color of the truck.They sell a gun that screws ontop of the can,i highly reccomend using this product.The spray gun will also fit onto the 3m undercoat cans.See the link !! http://products3.3m.com/catalog/us/...d_3_0/command_AbcPageHandler/output_html 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2006 Posts: 7 Junior Member | | Junior Member Joined: Mar 2006 Posts: 7 | Hey, I have used the body shulz also.I bought the gun that goes along with it.It does a real nice job.
Thanks Johnny
| | | | | Joined: Mar 2006 Posts: 9 New Guy | | New Guy Joined: Mar 2006 Posts: 9 | Rhino and Line-X are fairly evenly matched when properly applied. With a rubber based liner peeling is not usually an issue in metal that doesn't flex alot (beds, cabs) if the surface is scuffed evenly. As to fading, have you ever known of any product that retained it's color perfectly? It's a fact of nature that things fade, and black is the worst! There are products similar to tire shine that keep the liners conditioned quite well. And as far as coating the underside of a vehicle or using liners for sound deadening I have had nothing but good luck even with the cheaper Wal-Mart liners. The impact on road noise and heat transfer is well worth the time, not to mention the fact that is seals out rust. The one thing to remember is that if something is already rusty or unsound, adding a liner isn't going to help! Make sure it's prepped, and no matter how you go, it'll be better.
Need more space for VEHICLES in the list area! Maybe I just need to thin the herd...
| | | | | Joined: Mar 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 70 | we have a rhino type product on our deck of the wrecker body holds up well, then we got some do it yourself stuff for the other werker and it looked good but dried hard as a rock and chips easly, go with the stuff that stays softer. | | | | | Joined: Sep 2005 Posts: 2 Junior Member | | Junior Member Joined: Sep 2005 Posts: 2 | LINE X, the only way to go! Have them take the tailgate off and the bolts that hold the gate handle off, and spray separatly.
Fading is not an issue, they now have a reconditioner that can be applied years down the road to bring it black to a rich black.
good luck
OLDER IS BETTER
