7 members (32Fordpuchoptop, tclederman, 68ironhead, JW51, Shade Baby, 3B, Bill Hanlon),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,648 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 11 Junior Member | | Junior Member Joined: Dec 2003 Posts: 11 | I bought a mounting kit to install the cab of my 46 pickup. It consists of two wooden pieces about four inches long with a taper on one end, two round rubber pieces that are about two inches thick, two square and two rectangular pieces of 1/8th inch thick rubber. I have no remembrance of what I did when I took the cab off four years ago.
Does anyone out there know how these things are supposed to be used? I can only make a guess and I have no confidence that my guesses are any good.
Thanks | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | If i remember right the wood pieces go between the cab and frame at about the middle of the cab. The rubber pieces are for the rear cab mounts. The rectangular rubber is for the middle mounts the square rubber is for the rear mounts. I also made my own rubber pieces to fit between the frame and the front mounts. | | | | | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Follow the link in the previous post. It works very well.I used it to put the cab back on my 42 1/2 ton pick up. Thank goodness this site is avaliable. | | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | We aim to please. Sometimes we miss ... but we aim Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | I haven't seen you miss yet-- THANK YOU | | | | | Joined: Dec 2003 Posts: 11 Junior Member | | Junior Member Joined: Dec 2003 Posts: 11 | Wow
I am amazed! The above link had EXACTLY what I needed. Even pictures!!
thanks rick | | |
