0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | I know this is way off topic but I think someone here might be able to help.
I have a refrigerator I want to paint. It is white and slightly textured but glossy.
What would you reccomend I do to paint it?
Scuff prime and paint with whatever?
Sandblast prime paint
Just paint?
Thanks, | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Use appliance epoxy paint. Check out your friendly neighborhood ACE hardware. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | GMCpanel is right. They have appliance paint just for that. No need to sandblast - the instructions come with the paint. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | ditto on the appliance paint. make sure surface is clean. someone over the years might have used arag that had furniture polish or something like that to clean it .could have had silicon in it would lay waste to your paint job. 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | pretty colors? not avacado or almond? | | | | | Joined: Feb 2006 Posts: 20 Junior Member | | Junior Member Joined: Feb 2006 Posts: 20 | I haven't used the appliance paint but have done a couple of fridges in a fire truck theme using PPG automotive paint straight over the preped existing finish. I first disassembled the fridge by removing the doors and seals. This ensured I had paint in all areas. Looks tacky to have the seal move and reveil the old color. Then I degreased it using Pre-Kleano and scuffed the entire fridge using a 3m scuff pad, blow it off degrease again and then tack it off. The fridges I have done were raffled off at firefighter charity functions, they turned out great
Allan S Langley B.C Canada
| | | | | Joined: Feb 2006 Posts: 6 Junior Member | | Junior Member Joined: Feb 2006 Posts: 6 | Appliance paint.... and for a really cool fridge... www.goldrushsigns.com/beervaults
sure it's a nice paint job..... but something is missing!
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | How about black with a flame job? | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Black with flames insures your beer is 3 degrees colder! Its just that cool....  | | |
