2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1197575 12/30/2016 8:42 PM
Tried to get to the axle /hub seals today. Got tires off, axle shaft out, brake drum off, and stuck there. I don't have a 3.5" socket for the hub nuts. Tried somewhat gentle beating (is there such a thing?) With mallet and flat head driver to no avail. dang
Well at least everything is loosened up? grin
Did find inside of inside wheel had original paint under the grime.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
52vff #1197588 12/30/2016 9:49 PM
I made a socket to get mine apart. Turned out they weren't very tight at all. Just snug.
1950 4100 - unrestored and driven weekly for almost no reason at all.
52vff #1197594 12/30/2016 10:42 PM
Okaay. Made one? How?
"Old Smokey'"
52vff #1197629 12/31/2016 3:07 AM
2 Offline
There should be a locking tab folded down onto the outer nut someplace, maybe two... didn't see them mentioned in your post so thought I would mention them. Sometimes they blend in pretty good and if you're not looking for them might miss them, but they make a huge difference in being able to turn the nut off.
1946 Chevy Pictures
1946 Chevrolet 2-ton. In family since new. Splash oiled 235, 4 speed main, 3 speed aux, single speed 6.17 rear. Original GM supplied 12' stake bed, paint on sideboards is still from the factory.
Ride Along Video!
Ride Along with a little load
Video Channel
52vff #1197680 12/31/2016 3:30 PM
I found mine on ebay. Quicker than me making one. X2 on checking for the locking tab under the grease.
3 1/2" axle nut sockets
SimS
52vff #1198330 01/05/2017 3:04 AM
Found the best solution... Borrowed one from a friend. Locking ring only had tabs bent onto back nut, not front. Got passenger side off and have two new seals and hub gaskets ordered. However, went to try to get driver's side off, but axle flange bolt tapers(?) won't come loose. Even when hitting flange with sledge.
Too dang cold to try anything else right now -18‘C in the wind, or 0‘F for most..
I'm thinking penetrating oil or mild heat, any other suggestions?
"Old Smokey'"
52vff #1198386 01/05/2017 4:43 PM
I had the same issue on my fire engine rear axles. I ended up jambing two nuts together on the studs and backing the stud out with the tapered wedges.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
