| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Tried to get to the axle /hub seals today. Got tires off, axle shaft out, brake drum off, and stuck there. I don't have a 3.5" socket for the hub nuts. Tried somewhat gentle beating (is there such a thing?) With mallet and flat head driver to no avail. Well at least everything is loosened up? Did find inside of inside wheel had original paint under the grime. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | I made a socket to get mine apart. Turned out they weren't very tight at all. Just snug.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | There should be a locking tab folded down onto the outer nut someplace, maybe two... didn't see them mentioned in your post so thought I would mention them. Sometimes they blend in pretty good and if you're not looking for them might miss them, but they make a huge difference in being able to turn the nut off. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | I found mine on ebay. Quicker than me making one. X2 on checking for the locking tab under the grease. 3 1/2" axle nut sockets SimS | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Found the best solution... Borrowed one from a friend. Locking ring only had tabs bent onto back nut, not front. Got passenger side off and have two new seals and hub gaskets ordered. However, went to try to get driver's side off, but axle flange bolt tapers(?) won't come loose. Even when hitting flange with sledge. Too dang cold to try anything else right now -18‘C in the wind, or 0‘F for most.. I'm thinking penetrating oil or mild heat, any other suggestions? | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I had the same issue on my fire engine rear axles. I ended up jambing two nuts together on the studs and backing the stud out with the tapered wedges. Mike B  | | |
