8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | What was the original rim width and tire size on my 54 1/2 ton? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 6.00 x 16" tires on a 4.5" rim (a rim which was used with both 6.00 and 6.50 tires) | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Thanks Tim - I bet my truck will steer a lot easier if I replace the fat tires and 8 inch rims with something closer to original | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | If you want to go with original tire sizes your only option is someplace like Coker. Modern tires have a different sizing number system and if you search the forums someone has listed the modern tire sizes you can use. They are close, but not exact. I bought my tires online from Coker for my 54 1/2 ton using original rims. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | redwing,
I have LT235/85R16 radials on my original 1954 3100 wheels. One set with tubes and one set without tubes. They have a high-profile narrow-look like the original 6.50x16" tires.
After adjusting/servicing the steering gear (and all steering system parts), and after doing the Shop Manual steering system adjustments, and after playing with the tire pressure, the truck steers and turns and tracks much better than it did with bias ply tires. | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I'm not looking for a perfect match. I just thinking a narrower tire and rim with the proper set-back will steer a lot better than the 8 inch rally wheels with 235-70's that are on it now. Finding it hard to locate old-school rims. May have to go with Coker | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | If you can only find 4 inch wide rims they are ok to use (that was the case on my 55 1st series)
1955 First Series 3100
