0 members (),
44
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11971 07/06/2003 8:01 PM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Can anyone tell me what carb I should buy to go onto a 1946 chevy (216) truck...When I bought the panel the PO. handed me a couple of boxs of motor parts...but there was no carb..any help will be greatly appreciated.
1946 chevy 1/2 ton panel 1937 ford coupe | | |
#11972 07/06/2003 11:37 PM | Joined: Feb 2003 Posts: 1,375 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,375 | I have a couple of the original 40s carbs that I am not going to use,and a couple of distributors too. Let me know Jeff | | |
#11973 07/09/2003 7:25 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | JD:
216's were originally equipped w/ Carter W-1 from 1937 through1948, then they received Rochester "B"s, but beware, the 216 has a smaller carb mounting on the intake....so 235 Rochesters won't fit.
Somebody else here will probably post the spacing between the carb studs for a 216.
Aftermarket replacement carb would've been the Carter YF.
Either the W-1 or the Rochester B are decent carbs.
Frank McMullen
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
