Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy), 57 guests, and 2 robots.
Topics128,008
Posts1,055,285
Members48,418
#11971 07/06/2003 8:01 PM
Can anyone tell me what carb I should buy to
go onto a 1946 chevy (216) truck...When I bought
the panel the PO. handed me a couple of boxs of
motor parts...but there was no carb..any help will
be greatly appreciated.
1946 chevy 1/2 ton panel
1937 ford coupe
#11972 07/06/2003 11:37 PM
I have a couple of the original 40s carbs that I am not going to use,and a couple of distributors too. Let me know Jeff
#11973 07/09/2003 7:25 PM
JD:
216's were originally equipped w/ Carter W-1 from 1937 through1948, then they received Rochester "B"s, but beware, the 216 has a smaller carb mounting on the intake....so 235 Rochesters won't fit.
Somebody else here will probably post the spacing between the carb studs for a 216.
Aftermarket replacement carb would've been the Carter YF.
Either the W-1 or the Rochester B are decent carbs.
Frank McMullen
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
