3 members (Lostbuthaulinass, Ponchogl, RLB), 71 guests, and 3 robots.
Topics128,049
Posts1,055,743
#1196123 12/20/2016 12:55 PM
Any one have or know of a old bus? looking for shock bracket
1959 Chevy Viking 60 & Wrecker
See I told you it would work. That Beaver Cleaver will do anything.....
Big Bolt Forum Moderator
You might want to post this in the parts wanted forum, that is really the proper place for it.
Do you know if all the 57-59 busses had shocks? I know it was an option on the big trucks but I think most of them were bought without (mine are both old grain/farm trucks, and probably spent most of their life in a field or on a gravel road).
I scavenged shoocks and brackets off a 69 Ford step van. You might find something that will fit off an old step van or moving truck.
Mike
I'm guessing Mike is right. Shocks were likely an option but you might find what you are looking for at a scrap yard on an original truck chassis. I had to make a set for my '46. Best of luck.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
the bottom brackets off my stepvan bolt onto the nuts on the axle U-bolts. As long as the leaf springs are the same width off the donor truck I would think they would work fine. Then the top mounts bolt (or were riveted) through the frame.
Mike
Many thanks for the help. A bus usually had the brackets. The one a salvaged did all but one! Just my luck.
School Bus type chassis, or City Bus type chassis ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
School bus verison
