| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | Any one have or know of a old bus? looking for shock bracket
1959 Chevy Viking 60 & WreckerIn the Stovebolt GallerySee I told you it would work. That Beaver Cleaver will do anything..... | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | You might want to post this in the parts wanted forum, that is really the proper place for it.
Do you know if all the 57-59 busses had shocks? I know it was an option on the big trucks but I think most of them were bought without (mine are both old grain/farm trucks, and probably spent most of their life in a field or on a gravel road).
I scavenged shoocks and brackets off a 69 Ford step van. You might find something that will fit off an old step van or moving truck. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | I'm guessing Mike is right. Shocks were likely an option but you might find what you are looking for at a scrap yard on an original truck chassis. I had to make a set for my '46. Best of luck. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | the bottom brackets off my stepvan bolt onto the nuts on the axle U-bolts. As long as the leaf springs are the same width off the donor truck I would think they would work fine. Then the top mounts bolt (or were riveted) through the frame. | | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | Many thanks for the help. A bus usually had the brackets. The one a salvaged did all but one! Just my luck. 1959 Chevy Viking 60 & WreckerIn the Stovebolt GallerySee I told you it would work. That Beaver Cleaver will do anything..... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | School Bus type chassis, or City Bus type chassis ? | | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | 1959 Chevy Viking 60 & WreckerIn the Stovebolt GallerySee I told you it would work. That Beaver Cleaver will do anything..... | | |
