1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | Gotcha.
I was reading back through a search trying to find a source for an original style fuel pump from my 1935 1!1/2 ton Chevy. No luck (of course!). However, I stumbled across something regarding my 1958 1 1/2 ton GMC (370) grain truck. I'm always looking for threads about the two speed axle. Shortly after I got it the electric shift motor quit working. The brushes had worn completely down. I ended up flipping the brushes and shimming them out. I do use the truck for heavy loads frequently on the farm and split shift it a lot so I know I need to be on the lookout for a permanent fix.
I just read in an old thread that even GMC didn't have electric two speed until the early 60's. Is this correct? I'm the third owner of my truck and it's been very untouched right down to all of the oil change stickers and records. I can't imagine another farmer paying to swap it out - most do what I did for months: get it into high and leave it there. When did electric two speed come into play for the 370? | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The dealers that sold big rigs had a lot of leeway as to how they ordered and sold their trucks. Buyers could choose their preference for specific types of equipment, within reason. Is there a specification sheet (sometimes a metal tag) on the inside of the glove box door? If so, it usually lists the engine, trans, and rear axle options the factory installed. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The electric 2 speed shifts a lot smoother then the vacuum. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | The tag is there. I'll have to look at it. Originally this guy ordered two trucks just alike and hauled a distance, so electric makes sense. I'll look when I'm in that shed later. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | More than likely you have an Eaton rear. It will have a red push/pull switch on the gear shift lever. Old style replacement Eaton motors can be found, you just need to search, they were used by all truck manufacturing companies. Mike B  | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 |
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | If you take the motor off and into a local old time electric motor guy (one who fixes not replaces), brushes should be able to be found to replace those.
