4 members (Bill Hanlon, KEVINSKI, Gdads51, Otto Skorzeny), 130 guests, and 3 robots.
Topics128,164
Posts1,056,982
Members48,458
Gotcha.
I was reading back through a search trying to find a source for an original style fuel pump from my 1935 1!1/2 ton Chevy. No luck (of course!). However, I stumbled across something regarding my 1958 1 1/2 ton GMC (370) grain truck. I'm always looking for threads about the two speed axle. Shortly after I got it the electric shift motor quit working. The brushes had worn completely down. I ended up flipping the brushes and shimming them out. I do use the truck for heavy loads frequently on the farm and split shift it a lot so I know I need to be on the lookout for a permanent fix.
I just read in an old thread that even GMC didn't have electric two speed until the early 60's. Is this correct? I'm the third owner of my truck and it's been very untouched right down to all of the oil change stickers and records. I can't imagine another farmer paying to swap it out - most do what I did for months: get it into high and leave it there. When did electric two speed come into play for the 370?
The dealers that sold big rigs had a lot of leeway as to how they ordered and sold their trucks. Buyers could choose their preference for specific types of equipment, within reason. Is there a specification sheet (sometimes a metal tag) on the inside of the glove box door? If so, it usually lists the engine, trans, and rear axle options the factory installed.
Riding in the Passing Lane
The electric 2 speed shifts a lot smoother then the vacuum.
1972 Chevy c10 Cheyenne Super
The tag is there. I'll have to look at it. Originally this guy ordered two trucks just alike and hauled a distance, so electric makes sense. I'll look when I'm in that shed later.
More than likely you have an Eaton rear. It will have a red push/pull switch on the gear shift lever.
Old style replacement Eaton motors can be found, you just need to search, they were used by all truck manufacturing companies.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I'm guessing your shift motor is like this one...or very similar
http://www.thirskauto.com/heavy-duty-truck-parts/two-speed-axle-parts/sst_40635.html
1950 4100 - unrestored and driven weekly for almost no reason at all.
If you take the motor off and into a local old time electric motor guy (one who fixes not replaces), brushes should be able to be found to replace those.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
