1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I'm converting to a power steering kit that puts a 69-87 box on the outside of the frame. Trying to decide what to do about a steering column. Later model tilt Chevy? or IDIDIT column? or modify the original? Have you ever cut an original column to accept a bearing and universal joint? I see a u-joint offered that converts from the smooth original round shaft to the common DD. I am concerned about a failure-proof connection to the original round shaft. Also where to cut the original shaft and tube. Another question - How likely am I to find a junk yard power steering box in good condition, or should I just spring for a new one and not take the chance? I'd like to hear what choices others have made. | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | redwing: I've done a few of these conversions. Just finished one 2 days ago. I cut the column about 2"s away from the firewall, but cut the shaft a couple inches longer to fit a u-joint to it. I mill 2 flats on the end of the shaft to create a double D. Fit a bearing inside the end of the column. On this last conversion I used a 58-65 Ford pump that has the reservoir on top of the pump. I make my own pump mounting brackets that bolt to the front of the engine in 3 places which is a very clean looking design with easy adjustment. This setup is for using the original generator by adding a double pulley to it and running a separate belt to the pump. Very nice looking and working setup. I'd be willing to make the mounting brackets if needed. Dave V
| | | | | Joined: Aug 2006 Posts: 22 New Guy | | New Guy Joined: Aug 2006 Posts: 22 | Just curious... Have you guys ever thought of doing electric power steering? I had never heard of it until a friend had a shop add it to his 50 ford p/u. It is very clean looking, no pump to add, motor is pretty small. With key switch "on" you can turn the wheels with one finger.
I don't know anything else about this but I was impressed with how clean it looks and how well it works. I'm thinking of adding this to a hard steering tractor that I have???
Bob.
52 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Adding power steering is only half of project. Replacing my sloppy, worn-out original steering box is the other half.
| | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | DaveV- do you use junkyard power steering boxes for your projects or buy new/rebuilt? | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Thanks for the reply DaveV. Good advice. I have the ability to mill the shaft double D and fabricate about any bracket. My 235 has an alternator with a very small single pulley. I plan to drive the steering pump from a double water pump pulley on the 235 until I find and upgrade to a small block V8 with a multi-groove crank pulley. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Another option is to use an electro hydraulic power steering pump. They mount anywhere and the hoses run to the gear box just like ones from a belt driven pump. We used Toyota MR2 ones till they got scarce and very pricey. Now ones for a Mazda 3 can be found on ebay in the $100-$200 dollar range.
Evan
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Redwing: I do use junk yard steering boxes and never had a problem. I did do a conversion on a 49 with a 58 235 using a double water pump pulley and had to move the radiator forward for clearance issues. Dave V | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Ok - Now the next task is to find a double water pump pulley for my 235 long shaft water pump. I know that a short shaft pump is also available for this engine but I prefer not to change it. I may attempt to fabricate a double from two pulleys, but aligning the second pulley without wobble will be a good trick. | | |
