2 members (78buckshot, NJC), 98 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
OK, planning to do a transmission change and will eliminate the torque-tub system. Plans are to use a spare 70-81 Camaro axle laying around, as long as it is still in decent shape.
For those who have done axle swaps, what leaf spring set-up(s) have you used? Posies, Chassis Engineering, TCI, etc....?
Looks like CE and TCI have kits that relocate the shock mounting position and have wider springs (not sure if that helps with anything or not really).
Posie springs are stock narrow width, but still use the stock shock mounting position.
Thoughts?
1952 Chevy 3100 (235CI engine)
...T5 swap in progress...
I used my stock '37 springs for years, this last year I switched them out for new ones special made by Detroit Spring. I went with a softer spring rate for softer ride. If you plan on hauling stuff, stick with stock replacements. Also stick with stock width unless you plan to remake the whole spring setup. Changing the spring hangers for wider springs looks like a whole lot-a work thats not really needed.
Decide how you plan to use the truck before purchasing springs. Check the INFO packet from GM for stock spring rates and be sure to ask the seller of new springs what there rates are. I can tell quit a difference just going from 190 (stock ) to 140 spring rate on the rear.
The biggest load this thing will be is to carry a cooler and maybe a few lawn chairs in it from here on out. smile
4rcFed: on my 50 1/2 ton I used a 73 Camaro posi rear end w 3.73 gears; found some 90ish S-10 rear springs and used S-10 rear hangers too. Fabbed the front mounts myself; relocated the shock mounts. I'd suggest at this point, as viewed from the side, that now is the time to consider locating the centerline of your axles to your satisfaction in the middle of the rear fender openings. Seems the factory 116" wheelbase had the original axle a few inches too far forward. Good luck. Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
I have a 50 gmc 1/2 ton , I am putting in an 82 camaro rear w/2.73 ratio and an sm420 trans with a 292 inline 6. I've read posts about swapping the springs from front to back so the axle is more toward the center of the wheel well, so I'm trying this . I am fabbing rear shackle mounts with parts from Barnes4wd.com as mine were worn. it seems to be working well.
By swapping front to back, I hope you meant reversing the rear springs.
Since you are replacing the rear axle, why not just drill a new locating hole in the Camaro spring perches? The springs will work better in the as designed position.
82 camaro has coils.this truck had helper springs , and I'm using the perch from them turned around. yes, i am referring to reversing the springs.I have a set of 7" rally wheels i would like to use, but don't think they will work on the front. anyone have experience with what tire /wheel combo will work? not dropping the stock front end, and plan on using 75 series or taller tires.
What do you plan to do about the miss match lug nut pattern front to back if you use a Camaro axle?
I used a '79 Camaro axle with a aftermarket front disk brake set. The rotors match the rear axle, fact both are from the 70-81 GM F body line.
My front wheels are 15" diameter x 4" wide with a 205/75R15 radial. I went this way for easier steering. Wide tires and manual steering do not get along! I also run 40 PSI air to help with the steering. Rears are 235/75R15 on a 7" wide wheel.
thanks for the info. In fact ,that is exactly the way I am going.I have seen 4.5" rally wheels available.
