1 members (Cosmo), 76 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
Is there a vendor that sells the lower mounting bolts that mount the radiator core support to the frame for a 1955 3200 TF truck? I see the mounting pads, but not bolts.
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
have never seen them offered, but there's an assembly manual pic HERE - not hard to make up what's needed, the "shims" are thick flat washers and the "cushions" can be cut out of rubber from a tire sidewall or conveyor belting, for "spacers" cut a piece of tubing to suit
The nuts are locked on the carriage bolts so tight, I'm afraid they'll snap. If I have to replace em, does everyone just use a regular bolt and slide a wrench at the bottom mount and install a nylock nut on top?
more likely the floating nuts will rip the cages loose, but in any case ya gotta get things apart .... lotsa repeated loosen-all applications over time, maybe some heat, eventually you'll get'em, the bolts can be replaced from a hardware store, nuts too if they can't be cleaned up
Thanks for the input. I couldn't save em. I'll deal with replacement parts later. Spent the day installing engine & trans, fitting headers and determined the throttle linkage will not work in my truck (always something, transmission housing in the way), Now the switch to throttle cable instead of throttle rod.
Crusing in the Passing Lane
Heat will be your friend, get them red, when they cool some squirt some oil on the threads. Sometimes can hand loosen afterwards.
Ed
