3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | Is there a vendor that sells the lower mounting bolts that mount the radiator core support to the frame for a 1955 3200 TF truck? I see the mounting pads, but not bolts.
Admin for Turbobuick.com 87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | have never seen them offered, but there's an assembly manual pic HERE - not hard to make up what's needed, the "shims" are thick flat washers and the "cushions" can be cut out of rubber from a tire sidewall or conveyor belting, for "spacers" cut a piece of tubing to suit Bill | | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | The nuts are locked on the carriage bolts so tight, I'm afraid they'll snap. If I have to replace em, does everyone just use a regular bolt and slide a wrench at the bottom mount and install a nylock nut on top?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | more likely the floating nuts will rip the cages loose, but in any case ya gotta get things apart .... lotsa repeated loosen-all applications over time, maybe some heat, eventually you'll get'em, the bolts can be replaced from a hardware store, nuts too if they can't be cleaned up
| | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | Thanks for the input. I couldn't save em. I'll deal with replacement parts later. Spent the day installing engine & trans, fitting headers and determined the throttle linkage will not work in my truck (always something, transmission housing in the way), Now the switch to throttle cable instead of throttle rod.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Heat will be your friend, get them red, when they cool some squirt some oil on the threads. Sometimes can hand loosen afterwards.
Ed
