| | | Forums66 Topics128,180 Posts1,057,160 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | The throttle rod on my 1949 3100 with the 216 cu.in. engine is really worn at the pivot points. I have checked all the known vendors for this part with no luck. The rod I need is the rod from the carburetor to the linkage on the side of the block with the return spring tab. Does anyone know where I can get a NEW throttle rod or what are you guys using for this rod with the spring tab?
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | My suggestion would be to cut off the worn elbow(s), run a 1/4" fine thread die over the end(s) and grab one (or 2) of these from your local FLAPS.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Tim,
I weld the worn portion and grind back to the original configuration. With some patience, the result is very satisfactory.
Paul | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Thank you CurtB and Paul for the suggestions!! So, I take it there are NO NEW rods available on the market?
Tim
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I needed what I think you need. Please forgive, but I found that a Ford rod was available from "Mac's Ford Parts" that fit. "Bob Drake" also others also carry them. Shhhhh, "Loose lips sinks ships"!
