Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (UtahYork, Peggy M, Bill Hanlon, dt235sd, Hush), 115 guests, and 5 robots.
Topics128,290
Posts1,058,559
Members48,492
The throttle rod on my 1949 3100 with the 216 cu.in. engine is really worn at the pivot points. I have checked all the known vendors for this part with no luck. The rod I need is the rod from the carburetor to the linkage on the side of the block with the return spring tab. Does anyone know where I can get a NEW throttle rod or what are you guys using for this rod with the spring tab?
Tim
1970 VW Beetle
My suggestion would be to cut off the worn elbow(s), run a 1/4" fine thread die over the end(s) and grab one (or 2) of these from your local FLAPS.
You Tube
Tim,
I weld the worn portion and grind back to the original configuration. With some patience, the result is very satisfactory.
Paul
Lots more pictures
Thank you CurtB and Paul for the suggestions!! So, I take it there are NO NEW rods available on the market?
Tim
1970 VW Beetle
I needed what I think you need. Please forgive, but I found that a Ford rod was available from "Mac's Ford Parts" that fit. "Bob Drake" also others also carry them. Shhhhh, "Loose lips sinks ships"!
