2 members (homer52, Tronman), 239 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#119552 02/14/2006 3:34 AM
Hello, I have several small pin holes under the back window, on the outside, above were the two panels meet. I'm considering the options of what method of repair would be best. The paint shop up the road told me i'd be better off cutting out the entire strip and replace with new metal. But there is only a few holes and i can see that lead filling on the rest of my truck has lasted the best So i'm more inclined to try that. Then spray some rust perventative to inhibit any more holes. however it is a sealed panel. So i'm going to drill a hole behind were the seat would be and install a rubber gromet when i'm finished. What do you guys think? (before i start)
Brendon
problem is that when you start working on that stuff, I bet the holes open up and you get more of em. Usually the metal has gone paper thin when you see that stuff.
