5 members (52Carl, Bill Hanlon, Danielbolt, 2 invisible), 47 guests, and 4 robots.
Topics128,180
Posts1,057,163
Members48,464
What special socket do I need to remove the rear flange nut? I think it is 1 15/16 nut but a socket that large wedges against the flange ID before the socket reaches the nut. Can not locate a thin wall jam nut socket that size. Can any one offer advice?
Turn down the socket o.d. in a lathe or grind it down to fit. Try not to get it to hot and mess up the strength of the socket
a lathe is your friend. I have turned down the OD of many sockets for such applications.
Try another brand socket. When they get that big the OD can differ enough between brands to make a difference.
Or turn one down as needed, I've done that a few times with no problems.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks to all that replied. The size of the socket turned out to be 2". I had a 3/4" drive socket in that size. I installed a 5/8 bolt through the hole wrapped in electrical tape to fill the hole so it would be centered. Ran a nut down to secure everything nice and tight. I chucked in a drill press on slow speed and filed the OD to fit. Took an hour of time but the nut came off. Would love to have a lathe!
Crusing in the Passing Lane
A bench grinder would also work, just make sure not to take the temper out of the socket.
Ed
