2 members (JW51, 78buckshot),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | Hello Folks : I need to replace transmission bearings in a '47 1/2 ton pickup with 3 speed floor shift transmission. I've looked at the factory repair manual and it shows them using special GM pullers to remove the main shaft and rear shaft. From experience, are these special pullers necessary or can the job be done with conventional pullers ? Transmissions seem pretty daunting.....any hints I need to know before I tear this thing apart ? As always, thanks for all your insights ! | | |
