2 members (78buckshot, Wheelie),
131
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Recently, in General Truck Talk, the question of creating a fender dimple for the spare tire came up. There is a Tech Tip here at the forum that describes the procedure. But what isn't clear are some of the dimensions and positioning of the template. From the Tech Tip picture you can see that the template is located 5 3/4 inches away from the inside of the fender which would leave something to the outside. Can't read that dimension. Also, can't tell how far up from the bottom to locate the template. AND, does the vertical axis have to be tilted to some degree. Is so, how so? Thanks guys (and gals) P.S. Is there a building plan for fabricating your own mount? The ones that come up on ebay have a rather large asking price for for a few rods and a plate w/ threaded studs. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | I don't have the answer to your prolem... but do you know how the bracket attaches to the bed? There are special holes through the bed angle and wood that attaches to a angle to the bottom of the bed. And also, do you know how the bracket attaches to the side of the bed? I would suggest try finding a dimpeled finder. Once in a while you will find one on e-Bay. Good luck! P.S. There is a little more involved than the diimple. Do you have the bracket? How does the bracket attach? 1953 was the first year for this option on the AD"s. If you have a 53 (without this option)or a pre 53, then you will have to do modifications to the bed to make the bracket to fit, like driling holes in the proper places. Here is a pic of mine | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | It's a beut !!! That's the color my wife wants me to paint it. Looking at the photo, there isn't much margin for error. Is there enough room to get a towel between the dimple and the tire? Can you measure the distance from the the decortive accent bump on the bottom front side of the fender to where the bottom of the dimple starts? I'll assume that the dimple is absolutely perpendicular to the tire. Having the inside demension ( 5 3/4 inches from the inside) and the up from the bottom should place it just about right. The bracket placement can probably be adjusted somewhat. As far as the bedside structure that supports the spare bracket, I haven't a clue. I would assume that there is some re-enforcing backing plate there to capture the bolts from the bracket. Is there anything obvious? By the way, i'm from Oceanside. Anywhere close to me? I'll be heading up to Compton in West LA @ noon tomorrow (Sat). On my way to the body and paint guy to bring him some pieces. Would love to have a peak at the assembly and, of course, to ogle your truck. Give me a call at 760-458-5702. I'll be leaving for work at o-dark 30 in the morning so will not see you reply. Thanks for the pic. -jeff | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Thanks rsgs, The guy who is doing the body/paint said he could do the surgery given the right dimensions. I'll be getting those off an orginal 53' soon. -jeff | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | rsgs, There is a fundamental problem here. You have a 59'. I have a 52'. Second series vs. 1st series. Your dimple is definately different than a 1st series fender dimple. But appreciate your generosity. -jeff | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | rattletrap 52, you are right, there is a fundamental problem here, there is not such a thing as as 52 second series vs. 1st series, 54-55 yes. And of course his 59 fender wll not fit your 52 bed!! | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | You're right AD. Slipped a bit when I included the 2nd series for his 59'. But you get the picture. rsgs, Being helpful is exactly what this forum is all about. Be it advice, directions, links, been there done that, life long learning or giving things away, we are all (?) here for that reason. And I do appreciate your generosity. Someone else with a TF might need that fender with its dimple. Why not post it on the swap meet? Thanks, -jeff | | |
