| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I have only seen 3 stove bolt flywheels, and all of them looked worse than that. That said, I have no idea what is acceptable to put into service. I ended up buying a 12v Sachs flywheel for an 11 inch clutch on Partsgeek.com for $68 because I didn't want to run a flywheel that had deep cracks in it.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Foto-goofup isn't cooperating with my computer, but in general, tiny cracks aren't terrible. Glazing is, a shiny finish that interferes with the clutch disc getting traction on the flywheel. Try getting a machine shop to grind (not cut) the friction surface to remove the glaze. Another common flywheel problem is hard spots that are difficult to machine or grind away, and they tend to be football-shaped. As the surface is machined or ground the hard spot gets bigger. The spot that shows on the surface is like the tip of an iceberg- - - -there's much more below the surface. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those "checks" look pretty deep to me. There also appears to be heat discoloration?
My machine shop tells me if they can get rid of checks and discoloration. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | All I'm getting is the little spinning icon, and it happens on every website I visit. That's why I use Hunt101.com as my pic host Jerry
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Jerry I can email them to you if it helps | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Guys thanks for the advice I piggybacked an earlier post last week The reason I'm doing a clutch is the truck sat with me not running for 14 years and was last registered in 91' according to the plate that was on it Ever since I got it running and driving, the throw out bearing would make noise when backing out or taking off After a while, it starting making noise when in neutral and the truck was actually bumping or shaking forward a bit.then the noise kept on when driving I was sure I would have found a broken clutch disc screw But upon taking everything out the clutch looks pretty good
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Better at least pull the side plate and look inside the transmission while you've got it out. If it's making noise with the clutch pedal out and the trans in neutral, the problem is probably in the transmission. Lurching forward in neutral really concerns me. Jerry
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Thanks again Jerry A few more details When the truck ran for the first few times, heard a metal squeaking noise At first thought it was coming from the timing chain cover It went away after press the cutch a few times. The lurching sometimes goes away too after pressing the clutch. The throw out bearing came out bone dry and the rear 2 motor mounts are not bolted in if this helps at all Thanks again | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I would let a trusted local machine shop that doesn't sell parts advise me on the unit's serviceability.
Ed
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Forty9, if you find a machine shop that sells a flywheel for our trucks- let me know!!! I have failed at finding a new flywheel (that fits) anywhere.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Per Norcal Dave, if you can get a new flywheel for $68 minus $30 they will charge to resurface= $38. Why even consider the old one? Your old one is toast!!! Do we know what truck this flywheel is on? https://inlandempire.craigslist.org/pts/5912880206.html
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Update: The new flywheel that I bought online does not fit my engine... it's got one dowel pin hole and it has a larger diameter ring gear, and the bolt pattern is larger. Probably fits a V8.
Now I get to pay return freight- yay. The parts listing said 1958 4.3 liter inline chevy 6 168 tooth ring gear. I thought that a 4.3 is a 261 cu in. I guess not.
Sending the flywheel back.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Nope, that will be a 265 V8 - - -one of the oddball bore/stroke combinations the small block V8's had. Are you looking for a 6V or a 12V stovebolt flywheel? I think I've got both. Drop me a PM. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | We need to kick liters (metrics) out of our country! Jerry/Dave maybe Suburban Lou wants the flywheel. Would be fair, his post.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Wish I could see it- - - -photo-butt doesn't work with my computer. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Nope- - - -all I get is that irritating little spinning icon. Jerry
