2 members (NJC, Cosmo), 116 guests, and 3 robots.
Topics128,089
Posts1,056,442
Members48,443
Fox
Offline
Reinstalled the transmission sm420 and in preparation installed the gear shifter. What a sloppy mess! Upon inspection the "dowel pins" on the top of the Trans cover plate were worn right out. Well, being handy (cheap) I wanted to tighten the gear shift up so to speak so it didn't flop all over the place.
Here's what I did.
1. Plug inside of gear shift hole with clean rag.
2. Lightly grind the outside of dowel flush to cover.
3. Punch out the dowel pins.
4. Get a 5/16" bolt with a shoulder on it. Cut off head. Cut shoulder to proper length to match the dowel on the inside of gear shifter hole.
5. Drill the dowel hole out larger (17/64" if I remember) to accommodate a 5/16" tap. Place a small magnet inside of hole to catch filings with that clean rag under it.
6. Install the shouldered bolt from the inside of the gear shifter hole outwards. I used needle nose vice grips and applied loctite to ensure it is secure. Cut off extruding tails of bolts.
7. Test fit/adjust as necessary to tighten up fit.
8. When satisfied reinstall shifter to see how it feels.
I used grade 8 hardware
This was quite easy, fast and is adjustable to suit your taste as to how much wobble you want in your 4speed shifter.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
ODSS Lawman
ODSS Lawman
Have any photos?
If so we may have a Tech Tip in the making
Good job!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
My first attempt as such repair I removed the old pins, reamed for 5/16" and tapped a short spring pin, or roll pin, in each side.
I'm about ready to do another and plan to just make up new pins as original and rivet them (peen over the outside) as they were.
I intend to make a little adjustable tool to hold the pins while riveting.. I'll take some pictures when I get to it.
Thanks for sharing,
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
' Offline
There are a few parts that can be replaced to take the wobble out of the SM 420 4 speed shift lever .
photos @ photobucket
Top Cover showing Fulcrum Pins - GM # 590282
http://i669.photobucket.com/albums/...0Cover/SM_420_Top_Cover__zpsiuyy4pdq.jpg
Fulcrum pins - GM # 590282
http://i669.photobucket.com/albums/...ver/SM_420_Fulcrum_Pins__zps7gma956l.jpg
Friesens Chevrolet
Sutton, Nebraska
phone: 402-773-5538
Friesens Chevrolet has ( 72 ) Fulcrum Pins in stock
Newton Motors
Glasgow, Montana
phone: 406-228-9326
Newton Motors has ( 37 ) Fulcrum Pins in stock
Shift Lever Spring - GM # 3683582
http://i669.photobucket.com/albums/...er%20Spring%20GM%20NOS_b_zpsxurteurj.jpg
Friesens Chevrolet has ( 8 ) Shift Lever Springs in stock
Newton Motors has ( 18 ) Shift Lever Springs in stock
Shift Lever - Cap & Cup ......GM # 590387 Cap superseded to GM # 3988627
http://i669.photobucket.com/albums/...0Lever%20Cap%20and%20Cup_zpsvd7ypc5b.jpg
Friesens Chevrolet has ( 5 ) Shifter Caps - GM # 3988627
http://i669.photobucket.com/albums/...ft%20Lever%20Cap%202%202_zpsy8tdw29r.jpg
Shift Lever Cup - Original GM # 590384 - RARE PART - very hard to find
http://i669.photobucket.com/albums/...ver%20CUP%20NOS%20GM%202_zps9sh3qmki.jpg
Shift Lever CUP - GM # 590384 superseded to GM # 3988628
Dan's GM Obsolete
Chinook, Montana
phone: 406-357-2615
Dan's has ( 14 ) Shift Lever CUPS - GM # 3988628
http://i669.photobucket.com/albums/..._Shifter_Cup_GM_3988628__zpsijafa9ey.jpg
Chicago Auto Parts
Saint Ann , Ill.
phone: 815-614-3122
Chicago has ( 1 ) Shifter Cup GM # 590384 in stock
Reverse Shifter Spring - GM # 591582 & Pin - GM # 591581
http://i669.photobucket.com/albums/...erse_Shifter_Pin_GM_NOS__zpsxvukuirx.jpg
http://i669.photobucket.com/albums/...ter_%20Spring%20GM%20NOS_zpsohai3y2d.jpg
Friesens Chevrolet has ( 2
) GM # 591582 Reverse Shift Springs in stock
Dan's GM Obsolete has ( 4 ) - GM # 591582
Reverse Shift Pin - GM # 591581
http://i669.photobucket.com/albums/...erse_Shifter_Pin_SM_420__zpsjmei5kkm.jpg
Friesens Chevrolet has ( 4 ) - GM # 591581 - Reverse Shift pin
Dan's GM Obsolete has ( 6 ) - GM # 591581
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
** Thanks for the great ideas. ** The fix presented by Fox seems like a very good fix if your not locked into being original. Thanks To All **
