3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#11944 04/11/2003 3:14 AM
I have a 235 engine with R-45 sparkplugs in it..
Is this the right pulg for it?..What else should
I use if it isn't..
1946 chevy 1/2 ton panel
1937 ford coupe
#11945 04/11/2003 3:16 PM
I am not sure what the manuals call for, but that is a fairly hot (heat range) plug. Sometimes it helps to have a hotter plug to keep from oil soaking and fouling if its a used engine. If your engine runs fine with no harsh pinging, don't worry about them. If it is pinging under a hard load, try a cooler heat range, R44, R43.... Chances are, these are just right for it. Joe
#11946 04/11/2003 10:05 PM
i run a ac - 43 plug in my 235
it does not have a radio, and you gather a little more attention when you drive by other vehicles cool
Yes, officer it's licensed.
#11947 04/14/2003 1:40 AM
HEY JD: I am running 45's in my 48 and it runs fine. DAVE
