3 members (1955 1 Series, Gdads51, 1 invisible), 75 guests, and 2 robots.
Topics128,037
Posts1,055,582
#119428 02/07/2006 12:46 AM
I have some painting to do on a RV doing the accent strips so will have to use tape to get some strips done should I remove the tape while the paint is wet or wait until paint has setup and is there a tape to use for this???
#119429 02/07/2006 7:59 AM
Wait. If its wet, you could foul the paint while removing it. I use the scotch 'green' tape at the paint supply store. It sticks very well, can even take some weather, and does a nice job. If you follow the jeep link in my sig you'll see what you can really do with this stuff if you go nuts.
