0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 4 New Guy | | New Guy Joined: Nov 2016 Posts: 4 | hey y'all, I'm new to the site, and just had a quick question. I recently rescued a 49 3100 from a 35 year nap. Been tearing into it and noticed the number 74 wiped into the paint on the passenger side of the firewall. It had to be done when the paint was wet and I don't see any evidence of repainting. This is my first chevy truck so not sure if this is normal. I'd appreciate any info. Thanks | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Perhaps last two frame or engine SN?
Ed
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My memory is fading but not long ago some posted a video, or maybe I seen it somewhere else, that actually show a line worker putting a mark on the inner fender. Basically signifying that it was ready for the next process, or maybe it was a dept. identifying number/letter. If I can find it I'll come back and post it. I'd had also "heard/read" that some of the marks indicated to the next operation a specific part, or option?
Didn't answer your question but I at least muddled the water some more! | | | | | Joined: Nov 2016 Posts: 4 New Guy | | New Guy Joined: Nov 2016 Posts: 4 | I have a picture of it on photobucket but can't seem to find it after logging out. is there an easier site to use? | | | | | Joined: Nov 2016 Posts: 4 New Guy | | New Guy Joined: Nov 2016 Posts: 4 | here, finally, is a picture of the marking.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Whatever it is, it would not be a practice of an assembly plant to create a stand out paint anomaly. That could have prevented the truck from selling. Markings, as stated, were usually chalklike marker. A paint dept worker would have to have a good reason to do that. Especially that big! Sure is nice paint for 67 years?
Conspiracy theories: 1. As you say "wiped" not with finger and don't see brush marks. Looks like paint stick width. 2. Looking at the ridges of the wipe and it's still green inside wipe trench, I can't believe factory paint was that thick when wet. 3. Inspector was saying >4 (greater than 4 mils thick). Was showing how thick it was. Never got fixed. 4. Seems more shinny than rest of firewall. 5. May not be original paint in that area. Can't tell. You, being a paint instructor, can decide if orig.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2016 Posts: 4 New Guy | | New Guy Joined: Nov 2016 Posts: 4 | I actually polished that area to make it show better. The paint on the firewall is all in good shape. You can usually tell when something has been reprayed pretty easily, but this isn't showing any signs of it. And I agree, I can't see this truck leaving the factory like that. It remains a mystery. Guess i'll chalk it up to just being a good conversation piece along with the 22 shell stuck in the drip rail. Thanks for the replies. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If it is original, it was not meant to stay there and it was not a production line marking, Way too big. A rare "slip thru the crack" maybe.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2015 Posts: 11 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 11 | Hi, I worked at an assembly plant in the paint dept's sealer section, I think what you are seeing is we would seal seams in the metal with a brush at the end of a wand, kind of like a pump up sprayer wand, some times after we would change a barrel of sealer you would run the gun some where to make sure the psi is correct and there is no air in the lines, you didn't want to do it on a seam because you may have air and cause a bad seal, under the hood they didn't say to much about the looks as long as you didn't put it in a spot that would be a problem with a fitment or over bolt holes. Roger
1955 5400 Lcf Cab going on p30 chassis 1949 3100
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Very interesting Roger. Good info. Do you think if someone chipped or cut into the ridge he could tell if it's paint or sealer? It would not be green, correct? What do you think the number means? Did you see firewalls that bad leave the factory? I would say if the factory was concerned about a bad seal, they would be concerned about that not-so-nice-looking BIG mark? Once a worker tested and saw how big it was, why didn't they scrape it off right away, somewhat? Never seen that test before, Maybe others have trucks like that and will post. Good trivia.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Jason, Neat trivia. In recalling your thread, I noticed some writing on a 1944 military hood. I was really hoping it was "Rosie the Riveter" wishing good luck to the troops...retracing the script revealed a little less glamorous message. Before enhancement After enhancement
| | | | | Joined: Aug 2015 Posts: 11 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 11 | Bartamos, I'd think if you cut into it the sealer may be light grey, that was the color we used, If you get under it and peel it off you could see bear metal or primer, we put all the sealer in the seams before it went to the prime booth,as far as the number only the person who put it there knows, Yes I've seen fire walls, floor pans, inside of doors, but I worked at the plant for 30 years so thats a lot of vehicles and if you look under a hood now you don't see too much of the fire wall,as far as cleaning it up we were running at 45-48 vehicles an hour and they didn't like it if you stopped the line,when contractors would be in the plant working they where told if they stopped the line it was 1000.00 per minute fine so they had to be careful. Roger
| | | | | Joined: Aug 2015 Posts: 11 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 11 | Bartamo, After looking at the picture again, maybe it was the first truck of the day on 7-4-1949 to go past the person doing the sealer. Roger
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't think so, 4th of July was a holiday.
