9 members (MNSmith, Otto Skorzeny, 1955 1 Series, TexasJim50, Hotrod Lincoln, ronsway, tclederman, Snowman51, Gray_Ghost),
128
Mod | | | Forums66 Topics128,164 Posts1,056,978 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello; Can anyone tell me when Chevrolet quit using poured mains on their 216 engines? I had a discussion with a friend and we would both like to know.
Thank you 59shortfleet | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I'm not sure the 216 ever had poured mains. Only the rods were poured.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | In 1948 Chevrolet changed the process of the mains to allow "precision fit" bearings to be used. Before that the bearing inserts needed to be line bored once installed in the block.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | In 1948 Chevrolet changed the process of the mains to allow "precision fit" bearings to be used. Before that the bearing inserts needed to be line bored once installed in the block. So it would be safe to say that '47 and earlier had poured babbit, steel-backed insert bearings? If they were designed to be line bored, then there had to be a significant amount of babbit bearing material on them.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Thanks to all for the information on the 216 main bearings.
much obliged, 59shortfleet | | | | | Joined: Feb 2004 Posts: 29,864 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,864 | The general term for this type of bearing is "semi-finished". Back when crankshaft grinding equipment was not as accurate or repeatable as today's high-precision machines, bearings had to be custom-fitted by boring and/or hand-scraping to get an acceptable fit and clearance. Another advantage to semi finished bearings was that a reground crankshaft could use the same bearing set as a standard-diameter one- - - -just bore the bearings to a smaller diameter. Cam bearings were also supplied as semi-finished for some engines. Jerry
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Can the later precision fit bearings be used in the earlier blocks?
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,864 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,864 | Can the later precision fit bearings be used in the earlier blocks? Possibly- - - -if the outside diameter is the same. It would be a situation of trial fitting and maybe shimming for the correct oil clearance, or maybe installing the bearings without the crankshaft in place, measuring to see if they're round, and grinding the crankshaft to fit the bearings. More than one way to skin a cat! It also might be possible to line bore the block for the precision bearings, if the OD is different. Jerry
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Can the later precision fit bearings be used in the earlier blocks? I do not know how they were going to do it. Though the machine shop that was going to rebuild my 1946 235 was going to convert it to bearing inserts. Though I got a free 1954 235 at that time and had that one rebuilt. Jeffrey | | | | | Joined: Feb 2004 Posts: 29,864 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,864 | They were probably going to convert the rods, not the main bearings. That's been done pretty regularly for many years. Currently, I'm working on a procedure to salvage "worn out" 216 and 235 crankshafts by using Massey-Ferguson rod bearings in rebored rods. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Starting in about 1948 Chev sold "precision fit" bearings to fit the 1947 and earlier engines, but cam to crank gear backlash could be a problem, because of the imprecise main line placement.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,864 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,864 | cam to crank gear backlash could be a problem, because of the imprecise main line placement. That's also something to consider when line boring a stovebolt engine. If it's done incorrectly the cam and crank gears bottom out. An engine with a timing chain instead of gears can end up with a loose chain and late cam timing. Jerry
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | So are the pre-48 blocks basically obsolete?
1951 3100
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | So are the pre-48 blocks basically obsolete? Just be ready to check everything and spend plenty of money.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I definitely learned something today.
I knew about the Babbitt connecting rod issue with 216s, but thought the main bearings were all replaceable across all years
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,864 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,864 | Be glad we're not addicted to Model A's or Model T's! Both of them have poured main bearings! Jerry
