| | | Forums66 Topics128,140 Posts1,056,466 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I am about to media blast my frame and can't afford to powercoat the frame. What is the toughest primer and paint for the frame, axles, transfercase etc? I have a paint gun so I plan on spraying it. Any suggestions would be great! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd recommend zero rust Bill | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | por 15 It mostly depends on where you live and the availability of these products. If one is sold close by and the other you have to mail order which will you choose?? I ONLY brush it. Bought a box of 50 latex rubber gloves, cheap ins. @ $5.00 I use http://www.por15direct.com/
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Be careful if you spray POR-15 -- You MUST use a respirator and be CAREFUL!!!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | John is absolutely right. I sprayed a frame in the open without a mask and spent the night in the hospital with pneumonia. That's some serious stuff. I try to brush it whenever I can. | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Jerry, I hope everything turns out alright for you. I did the same thing last summer when applying POR 15 using a faulty respirator and was in bad shape too. Sick for a week. My tongue and teeth were black. Make sure you wear gloves. I had also used a product called Chasis Saver. So far so good. I brushed it on. BrianM | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I definitely will not use POR-15, my life is worth more than my frame. I even use a respirator for sanding, that is how paranoid I am. Has anyone used Chassis Black? | | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | I "believe" POR-15 contains isocyanate. It's really nasty stuff. I have heard half a dozen horror stories about paints with isocycanate that have pretty much scared me away from ever using anything with it. I did a little research and almost all body shops use an external air source for breathing when spraying paint with iso in it. Do a quick search on the net and you'll see what I mean. Most auto paint suppliers can provide you with a safety sheet with the paint and it will advise you as to what kind of breathing apparatus is required. | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | POR 15 does indeed contain isocyanates. A simple organic filter mask is not sufficient protection, you must use an air supplied respirator. Here's a link to the POR 15 Material Safety Data Sheet (MSDS) Me, I painted my frame with XO Rust Red Metal Primer and XO Rust Satin Black from True Value hardware  Hell, its just an old pickup truck and the original frame lasted 50 years with less protection than that.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Bolters,
Isocyanates is the single biggest reason you see few old painters. I know guys who are so sensitized to Isocyantes they can't walk down the sidewalk outside a body shop where Isos are being sprayed. Once lung tissue gets sensitized to it, it's over. Some take a long time to sensitize, some get down almost instantaneously.
Now no one wants to spout the fact that their product has Isos but I do think the coatings industry & dealers should do a better job of schooling customers. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I'm with red58. I applied Zero-rust to the frame with a brush and sprayed the cab bottom and areas you can't see. It comes in spray cans too for touch ups instead of getting out the gun. It was super easy to use, available locally, and I will definitely use it again on my next project. I shot clearcoat over top of it on the inner tubs and they turned out great.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I use Eastwood's rust encapsulator now. It's much more freindly. I must admit though that I read the cautions from POR-15 and thought I'd be ok in the open air. I've brushed the stuff a few times since then and I still feel it if I use a lot of it. When I called them about my experience, they asked if I could read. Funny! | | |
