2 members (JeffA, Mike B), 167 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
#1193945 12/05/2016 3:11 PM
I
I Offline
Ok I've been trying to get my gas gauge to work, the sender and gauge are both new and I even sent them back and the guys at Jim Carter said they worked for them but sent me new ones anyway, it just sits on empty, if I ground out the wire going to the sender the needle will play between below empty and empty can anyone tell me what I'm doing wrong?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
Ian,
Take a look at this ARTICLE it should answer your questions.
Harold
Harold
Did you replace the wires from and to the gauge to the sender? and install a good ground from the tank/sender housing to the frame?
definitely have a look at the article.
Another quality post.
Real Trucks Rattle
make sure the ohms match up with the gauge and sending unit
sometimes they can get mix matched
Redryder pix
My Hotrod
I
I Offline
Ok I'll check that my grounds and such, all wireing is new so maybe I've missed a ground
(I'm 20)
"Lucy"
Ex Hall Monitor
Ex Hall Monitor
Fred makes a good point. If the resistance doesn't match between the sender and gauge you'll never get an accurate reading.
