| | | Forums66 Topics128,147 Posts1,056,798 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Ok I've been trying to get my gas gauge to work, the sender and gauge are both new and I even sent them back and the guys at Jim Carter said they worked for them but sent me new ones anyway, it just sits on empty, if I ground out the wire going to the sender the needle will play between below empty and empty can anyone tell me what I'm doing wrong? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Ian, Take a look at this ARTICLE it should answer your questions. Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Did you replace the wires from and to the gauge to the sender? and install a good ground from the tank/sender housing to the frame?
definitely have a look at the article.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | make sure the ohms match up with the gauge and sending unit sometimes they can get mix matched Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Ok I'll check that my grounds and such, all wireing is new so maybe I've missed a ground | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Fred makes a good point. If the resistance doesn't match between the sender and gauge you'll never get an accurate reading.
