| | | Forums66 Topics128,288 Posts1,058,569 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Anyone else have this happen? New wiper arms, new wiper transmission arms. Driver side wiper arm fits nice and tight on the transmission shaft and the passenger side arm fits, but it seems loose on the shaft? Removed it and measured the I.D of the arm and the O.D. of the shaft. Only .003" in difference. Any way to tighten this arm on the shaft? Splines line up good.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have taken apart a few sets from parts trucks and found a paper like material (remnant) so it might have been a chronic problem? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I noticed that paper type material or remnant thereof when I disassembled my old wiper arms and transmission. It was only on the passenger side. Thought...with the new wiper arms and transmission parts that the wiper arms would fit tight...NOT! Anyone know what that paper type material was? Thought it would have rotted over the past sixty years. It did, because there was only pieces of it. Did Chevrolet use this paper type material as a shim for the loose wiper arms? What would be best to use now? Something that won't deteriorate?
Tim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Brad,
You always find some of the most unique items for these trucks! That Trico wiper arm remover is really unique. Wish I could find one.
Anyway, any ideas on what I could use to tighten up the passenger side wiper arm on the shaft? Suggestions?
Tim
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Have you thought about using clear silicone as you push the arm on it should take up the extra space. Wipe off the excess and let it completely dry before you try it out. If it doesn't work it should be easy to take back to bare metal.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | This tool is helpful removing A-D wiper arms. I'd cob-tighten the fitting by using a strong plastic "shim" around the post (or, try to get a new/used post/transmission-shaft). | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They produce a shim tape in a variety of thicknesses (McMaster-Carr). Now I Googled it and see how it is sold, it might be what was used back in the day? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Brad,
Thank you for the lead o the shim tape. I think that is exactly what I am looking for. Will order from McMaster-Carr and see how that works out.
Tim
