1 members (Stovebolt48),
73
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Anyone have a good way to remove rust and paint from my rear window rubber seal?? The seal rubber seems to be in fairly good shape except for the body rust that has embedded itself into parts of the rubber. There are also remnants of several layers of paint that I would like to remove. I have tried a little wire brushing and some scraping, but wonder if there is an easer (lazy) way?? | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Might try a little WD-40 and let it set for awhile.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jan 2006 Posts: 3 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 3 |  Rusty Rubber
Whats up, Doc?
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Just buy a new one ,any glass shop should have that stuff in a roll.Take your old one in and they can match it up ! | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Originally posted by Elmer PHD: Rusty Rubber Maybe a typo and the C is missing.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I’ve tried some of the local shops and but none match the one that came off of the truck. I think it must be original as under the several layers of paint it has a little of the original blue. The rubber is nicely drilled for the window frame bolts and even counter-bored for the bolt bosses on the diecast frame. I ordered one from a mail order place but it did not match either.
Looks like I’ll try the WD40 | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | i dont know what truck you have, but I think i only paid $14 dollars for my rear rubber from Carters. Considering that an old one gets hard with age and yours is already rusty and dirty, I wouldn't even think twice about buying a new flexable one. | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Kip41, I bought a new rubber gasket from Chev's of the 40's and had to drill new holes. What a B**** to change. Good Luck lol | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Finally ......Someone who understands me (guess I shoulda specified its a '41) . I have the same gasket and it is going back! The WD-40 seems to be loosening the deeper rust and some of the layers of paint. With any luck a couple more days under the oil, then a light wire brush and a little ArmorAll will make it "like new" | | | | | Joined: Jan 2006 Posts: 30 New Guy | | New Guy Joined: Jan 2006 Posts: 30 | I had to reuse the rear gasket in the restoration of my 64 Valiant. I had to soak it in mineral spirits. It makes a mess with all the black coming off of it but it makes it plyable and cleans it very well. Make shure you wear rubber gloves and rinse it off realy good to get the excess off.
1966 C10 250/3 Stepside 1966 C10 327/3 Fleetside 1972 Buick Centurion 455/TH400 1964 Plymouth Valiant 360/A833 4spd 1964 Plymouth Sport Fury 440/727 I've got a new car....It was made in '72
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | For any of your rubber replacement parts I would recommend going directly to Steel Rubber. Their products cost more but the Quality is 10 times better than anyone else. This is important where windows are concerned, you don't want to be replacing the rubber again in 2 or 3 years. If you can salvage the original, go for it, otherwise contact Steel Rubber. George | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | 46: How was their service did you call and talk directly on a phone or just order on line. Ben
popcorn The Truth is Out There (Very close to get ready to order for doors and all windows) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pop - the service from Steele is excellent, and they'll admit and fix any mistakes they make - and considering they are THE repro rubber maker, well worth dealing with - they only make parts they know are 100% correct and they use they highest quality material formulations
I sent them some good condition original panel barn door seals to reproduce and they handled the whole thing well and reproduced the seals perfectly - talked to them on the phone twice, but either online or toll free ordering will be fine I'm sure, and their service reps DO know the products
Bill | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Thanks Bill! Saved ol Dads butt again. Problay just make a call I really like talking to a "live person" learn more.
popcorn The Truth is Out There (One more door to tear apart then sending stuff to Indy to chrome also)Ben | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | I just talked to Steel Rubber on the tel. talked to a lady named Karen. I think I am in love (southern drawl) very, very, friendly people. Thanks for the head up! Ben
popcorn The Truth is Out There (I love this sight) | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | did you get it delivered on time Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | The bad thing about removing a rubber window seal is that the rubber, originally installed tightly around the window, has shrunk and has held it's position only because a glass was in it.
More often than not, simply removing the glass allows the rubber to contract enough to prevent reinstalling. Add to that the loss of pliability, you can break a glass.
I installed glass for 15 years, been there, done that! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have the same gasket and it is going back! I had issues with the rubber I got from Chevs as well. The back glass rubber was destroyed trying to make it fit & the vent window seals were a joke. They were an inch too short. Try driving with a half inch gap at the top & bottom of the vent window in the rain while listening to the whistle. I don't know who made the back glass rubber but Metro Molding made the vent window seals. I bought replacements for both from Steele & they fit like a glove.
