7 members (GMCJammer51, 66flea, WICruiser, Jon G, dt235sd, 2 invisible), 92 guests, and 4 robots.
Topics128,064
Posts1,055,860
Members48,428
#1193228 12/01/2016 2:13 AM
Has anyone purchased a carb from Daytona Parts the make their own Rochester replacement carb.
thrs50 #1193232 12/01/2016 2:34 AM
Sir Searchalot
Sir Searchalot
Have not heard of them. Mikes Carburetors sells them for $339. Nice looking kit. What truck, motor and carb do you have and what do you want? Plenty of original carbs and kits. Easy to rebuild. If you have a good core: Jim Carter has Rebuilt for $175 (all on back order?). Classic Truck Parts $179.
thrs50 #1193250 12/01/2016 3:47 AM
My Blog
thrs50 #1193261 12/01/2016 4:46 AM
P.T. Barnum is alive and well, and selling carburetors!
thrs50 #1193262 12/01/2016 4:58 AM
Well, you only need two adjustments on a carburetor. The main metering jet and the size of the venturi. The metering jet would be no problem. Maybe he uses venturi of different diameters that slip into the throttle housing like Zenith did. Or maybe its kinda like what Jerry alludes to. Add a little more snake oil it it for a bigger motor.
thrs50 #1193265 12/01/2016 5:28 AM
How about power valve mixture, accelerator pump volume and velocity, part throttle transition, ported or full accessory vacuum, dashpot throttle closure rate, fast idle during choke operation, and about a dozen other tweaks that account for hundreds of different part numbers just for GM Quadrajet carbs alone? An engine might run with a one-size-fits-none carb, but performance and/or gas mileage will suck like a Dyson vacuum cleaner!
thrs50 #1193266 12/01/2016 5:30 AM
Sir Searchalot
Sir Searchalot
I meant Mikes Carburetors Sells Daytona for $339. Daytona had no pricing. Hate that. They look good but the castings and such are made in Argentina. Rather have China. smile Give me Rochester or give me Carter or give me Edelbrock (Carter) but ya doesn't has to gimme Universal.
thrs50 #1193268 12/01/2016 5:52 AM
Insomniac
Insomniac
$350. Add another $25 + GST if you are Canadian. Nice... frown
Here's another view:
Y200 Carb
Specs and exploded view:
Data sheet
Gord 🇨🇦
1954 1/2 ton 235 4 speed
thrs50 #1193456 12/02/2016 3:01 PM
Carburetion specialist
Have seen a number of various carburetors "reproduced" offshore over the last few years.
So far, the ONLY one I have seen that is useful for more than a paperweight is the model 97 made in England. They had some "teething" issues in the beginning, but a very reputable company, and now have a very useable product.
But if you enjoy rebuilding engines, go for the offshore reproductions!
And Bart - if you ever do a side by side comparison of an AFB clone to a genuine AFB, you will drop your third "gimme" wink
Jon.
The Carburetor Shop
thrs50 #1193457 12/02/2016 3:09 PM
And for those always looking for the cheapest price.....Google John Ruskin paying too little
Jon.
The Carburetor Shop
thrs50 #1193467 12/02/2016 3:54 PM
Yep, simply going for the cheapest price for a service is much sillier than thinking you get the best by paying the highest price?
Check out references and quality of work (and how fast they "deliver" that quality product)?
Check out how the "seller" backs the work/service/product, in the unlikely event that something goes bad too early?
thrs50 #1194109 12/06/2016 6:03 PM
My experience is limited with 235 carbs. I ditched the Rochester when it developed a leak, tried the holly weber from the pinto/vega era. Works well but too small for the top end Tried 2 holly webers, an expensive lesson in after market performance parts (the fenton intake was junk) And am now considering a single weber 38. It's supposed to be good for 6 cylinders with around 250 cubic inches. Not eager for another expensive lesson. Maybe another vintage carb?
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
thrs50 #1194124 12/06/2016 7:13 PM
To date, in 50 plus years of working on carburetors and learning lessons; my most expensive lesson was a Weber two-barrel IDA that even the so-called Weber guru's could not make to function as well as a $5. swap meet flattop Ford (Autolite) 2-barrel. This lesson cost me almost $2500. several years ago when we were sponsering one of the dirt-track 4-cylinder race cars. Was supposed to be the "hot" set-up.
Lots of vintage carbs that will work well on a 250.
For a 250 CID Chevrolet, I would personally look at a Zenith from a GMC 248, one of the aftermarket Strombergs, or a Carter YF from a 240 CID Ford if the idea was a single barrel.
For a two-barrel (if a good two-barrel manifold exists, NEVER with a 2->1 adapter), a Carter WCD or WGD, a Rochester 2GC, or a Stromberg WW.
Others may have other choices.
And if I mis-read your post, and you are looking for a carb for a 235, difficult to beat the Carter YF (pick the correct one for your year), as Carter designed several specifically for the 235.
Jon.
The Carburetor Shop
thrs50 #1194133 12/06/2016 8:25 PM
you say pick the correct one for my year, it's a 235 from 1954 with the 848 head (little higher compression) I'm using a 2>1 adapter now with the holly weber. A carter YF designed for a 235 sounds good. There's even a gentleman I see at area swap meets who sells vintage carbs he has rebuilt. I'll look into the carterYF
thrs50 #1194136 12/06/2016 8:40 PM
thrs50 #1194145 12/06/2016 9:29 PM
Thanks, great list
thrs50 #1194152 12/06/2016 10:55 PM
I am actually thinking about dual carbs
I have 1957 235 currently considering using Tom Langdons set up.
thrs50 #1194160 12/07/2016 12:38 AM
I have a YF2100 on my 235 with 848 head with a T-5 transmission behind it, and I do not need any more carburetor than that. I reach maximum RPM (screaming, as they say) quickly with every gear shift, and have plenty of gas pedal in overdrive at 65 MPH. I have never tried it, but I bet this truck will do 100 MPH.
Carl
thrs50 #1195815 12/17/2016 11:39 PM
Does anyone know the fellow somewhere in New York that has has a carb shop? I've called and spoken with him before but lost his number after my phone died last year. He used to post on Stovebolt occasionally because that's where I got his contact info. I have Carb King's info but would like to also have him in my reference library.
Thanks!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
thrs50 #1195818 12/18/2016 12:16 AM
Maybe Larry Isgro ?
thrs50 #1195885 12/18/2016 4:38 PM
That's him. Thank you very much!
Chuck
1941 Chevy coupe
