2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#119273 01/26/2006 2:34 PM
Its the middle of winter here in Michigan and cold in my garage. I would really like to get a jump on some paint and rust removal especially around areas like the windshield, back window and cowl vent that I'm rebuilding. It is a little too cold to apply primmer and I'm wondering if there is a coating that can be applied to prevent surface rust until it warms up a little (July). Has anyone tried a thin coat of WD40? It should be easily removable with a degreaser or metal prep.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#119274 01/26/2006 2:56 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have used a thin coating of 3-in-1 oil on bare metal parts that I am not ready to prime. Seems to work well in the Houston area. Just have to be sure to get it all off before spraying.
I also used some rust disolver from Home Depot on my hood. The results are very good although it took several applications. The metal has not re-rusted as yet as it seems to have left a film on the metal. To remove it will take a DA sander or a wire wheel.
#119275 01/26/2006 4:00 PM
kip's41,
Would it possible to do the body work, heat the bare area with heat lamps for awhile, then spray it with a aerosol can of etch primer.
My auto paint store has etch primer in aerosol cans and it comes in great for little jobs. It keeps the rust away until a permanent paint or primer is applied.
The array of heat lamps is something you see in many body shops.
Stuart
#119276 01/26/2006 4:29 PM
Apprentice
Apprentice
Sorry to hijack the thread, but what was the name of the stuff you got from Home Depot Houston54, and where was it located in the store? I looked there before but didn't turn anything up and the employee I talked to had no clue.
Kip, I'm in the same boat as you-Ohio weather hasn't been too bad lately, but it is still cold. I have been turning on the heat in the garage when I get home from work and by the time I actually get out there at 9:00 or so, it's comfortable. I've been using spray cans as suggested above and so far it is working. The directions say to paint in ~72*, but I've had no problems with 50-55* so far...
#119277 01/26/2006 5:38 PM
WD40 is a painters nightmare,that stuff will get into cracks and seams,sit there,then show it's fish eye face when whoever gets to paint it.my opinion (wet primer is better than oil). grin
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#119278 01/26/2006 6:00 PM
Anonymous
Unregistered
Anonymous
Unregistered
I cannot recall the exact name but I found it in one of the paint aisles. It is a rust disolver. Worked good for me and I had heavy surface rust and pitting. The container is still at home if you cannot locate it.
#119279 01/27/2006 3:05 AM
Thanks all !! Looks like the WD 40 idea is a no go. I'll try for heat lamps, a little local heat and wait till the primer drys. The old truck ain't going anywhere for a while anyway.
I'll also keep a watch here to see if anything turns up at Home Depot
#119280 01/27/2006 4:34 AM
Anonymous
Unregistered
Anonymous
Unregistered
The product name is Phosphoric Plus by Kleen Strip.
#119282 02/06/2006 10:16 AM
i just use cheap primer,red oxide. i primered fenders that were sandblasted and they sat 5months in a damp garage and they look great.
for a story on contents of soda, when i hauled over the road i used to haul chemicals to make coke,some nasty stuff, had a 53' trailer all i can carry is 2 fifty five gallon drums in very front,secured well.1 20 gallon drum in the middle,secured well, and 2 1'x1' square boxes at the back doors. from new york to california hazardous placards on trailer,while getting loaded you sat in truck with 2 armed guards watching you.
#119283 02/06/2006 1:16 PM
go to any parts store that mixes paint and ask I have something that is from dupont that is a wipe on...
#119284 02/07/2006 2:25 AM
I used a product bought at FLAPS called Right Stuff. One quart about 5 bucks. Has phosphoric acid. I put in a spray bottle and pumped into frame nooks and crannies. Smells a little nasty and turns black when dry. Seems to work OK. I them cover with a primer. Directions say to use above 38 degrees but I've used at lower temps just took longer to dry.
Dan
