3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I don't know if this needs to be in the electrical or HiPo section, I am converting hilborn injection to electronic, I would really, really like to make it work on a 6 volt system somehow, but I don't really, really think that will work. I went through the tech tips, and there is a 12 volt GENERATOR, and a 12 volt ALTERNATOR, I would like to use the generator for appearance sake (why, I don't know, those six stacks bear no resemblance to a stock engine, but I am weird like that) But I have also heard the power with a generator isn't stable enough or clean enough. Any ideas? | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | It sounds like an interesting project. If you don't get any answers here, we can move it to the HiPo section.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Hey Brokenhead, if we all stoned all of the weirdos in here, we'd soon run out of stones.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | What kind of current (amps) are you looking at?
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Rusty, you are so easy today......52Carl, how in the world did you slip in............................just joking
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The mid-1970's Volvo B30 engine was an inline six with Bosch electronic fuel injection. The injectors were triggered by a set of dual points riding on a cam on the distributor shaft below the breaker plate. If you can find one of those distributors you might be able to use it to fire the injectors with a minimal amount of electronics. The Volvo had a batch injection system where three injectors fired at once, and the other three were triggered on the next turn of the crankshaft. I owned a 1974 Volvo 164 with that system, and it was reliable, and spooky fast for a 4-door sedsn. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Beltfed, I don't really know, this is pretty close to the very beginning of this project. I am pretty sure I will need to go 12 volts, and there is the need for clean power, and have heard a generator won't provide stable enough power for the electronics. There is a couple of people on here that have done EFI conversions, I was hoping to pick their brains, Or is that in the tech tips too? I have spoken to hilborn, they can convert the injector body, and provide the brains but I will have to make a spacer or something because the injectors will hit the valve cover, not to mention #6 stack hits the firewall. There are couple of other options out there for that part, but right now I am trying to determine which way to go for the power. I even contemplated using 2 6 volt batteries, charge them in parallel, but pull the power off in series, if that could be done, I'm not even sure of that. I know we used to get 12 volts out of a 48 volt battery bank by just tapping one of the 4 batteries when I worked on the boats. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | I'm just spitballin' here: They do make 6v to 12v DC-DC converters. Consider driving your ECM only with one of these (there is one on eBay for <$20 that can drive 4A/48W load - you'd have to check the current draw of your computer/injectors). It says there is 40mV of ripple on the output which may or may not cause problems with your ECM. I'd put a large electrolytic capacitor on the output of the DC-DC converter if i were to try this.
I put a GM TBI system on a small block in a Camaro i built, and all of the sensors (there are only 5: IAC, O2, Temp, MAP, throttle position) were driven/monitored by the computer, so if the computer was running off the 12v then its possible the system would work. A multiport injection system may need more current, i don't know.
you could try the DC-DC converter idea before going to your twin 6V battery approach which should also work. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I don't think the entire engine management system draws much at all, but I don't know any exact numbers. Hilborns setup utilizes batch firing, which would be just fine, except I would really like sequential, just because. (yep, just weird that way) I have been looking into AEM systems, and there is a fella in arizona that does conversions too, but his are an extra $1,000. But this is good stuff, I'll check into it. And thanks for all the suggestions. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Interested if one or two injectors will work best in siamese ports? Has anyone tried?
Ed
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there are people who have done this, if I recall, one does fine, due to the relatively low RPM of these engines, it just gets fired twice. Two would undoubtedly work better. I am still trying to get hold of one fella that has done this.(actually does International harvester conversions for a living) however the manufacturer doesn't really make any difference to the computer. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | so I decided to bite the bullet and go with the powermaster alternator that looks just like a generator. It doesn't seem like I am going to get around going to 12 volts. Now I need to decide which way to go for the injection... Then the fun begins. | | |
