2 members (sron48, Gray_Ghost),
105
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Installed carpet and insulation in the floor of my 58 3100 and now I notice that I can't get full throttle because the carpet takes up a half inch of my range.I'm on the floor and running between 65 and 70 but the carpet does not let me bottom out the gas pedal. Is there a way to extent the accelerator rod without welding to use the half inch that the carpet is stealing? I'm running a 55 235 with 3.90 rear and overdrive. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The "without welding" stipulation throws a wrench to most proposals but you might check to see if the hole in the lever on the carb could be moved closer to the throttle shaft without causing the vertical accelerator rod to bind against something. The rod from the pedal to the bell crank on the pin in the side of the block could possibly have the hole on the PEDAL link moved closer to center. Again trial and error to check for clashes or binding.
Evan
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Does the rod from the pedal to the bell crank need to be completely straight or does it have a slight bow downward in the middle? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Get a piece of rod the same diameter. Then cut your rod. while at the Hardware Store buy 2 u-shaped cable clamps in the same diameter (or close) and use those to piggyback the rods together. You will then be able to adjust the length of the rod however you want.
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | It' good to know it has a bow because I was worried mine was bent. Rather than cut my original rod I would rather add something under the pedal or at the carb end. I may try to fab a piece to extend a half inch at the carb. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | What part of the pedal is contacting the bottom of the gas pedal? Can you carve out the section of carpet/pad to give you clearance?
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Carl, I was thinking the same Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That was my first thought also. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Well you late birds need to get up earlier if you ever expect to get the worm. (Or maybe I need to get a life.) Carl
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | The pedal attached sits with the top right corner at 2 o clock. Right now I am using a 1/2 to 3/8 socket adapter modified and attached between the accelerator rod and the gas pedal to regain the 1/2 inch I lost. | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | You need an adjustable bell crank, a longer radius will yield more push.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | The pedal attached sits with the top right corner at 2 o clock. Right now I am using a 1/2 to 3/8 socket adapter modified and attached between the accelerator rod and the gas pedal to regain the 1/2 inch I lost. Let's see a picture of that.
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I will try to get a picture posted. Did the adjustable bell crank come on the cars . I have seen lots of those on e bay but did no know if they would interchange on the trucks.
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Nope, didn't come stock TMK. Lengthening the rod is only going to put the pedal closer to you. If you are 6' or taller you need all the space. I'm 5' 11" and I just fit if I were taller (or the pedals closer) I would be hard pressed to put the mileage on that I do.
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I'm 6 ft 4 inches tall so if that is the case maybe I need to leave well enough alone. I did change my steering wheel from a huge catalina to a smaller chevrolet wheel and that gave me a lot more breathing room. | | |
